21615 Discussions
Taking FEC data out from PACN3000
SACHINKV
we are trying to enable LDPC FEC accleration in Flexran server using PAC3000 card. We were able to run the l1app with Fec accelaration and the testmac testcases are passing. We are also able to run the test-bbdev application. Now we want to bring out the encoded data from the PAC through the Ethernet interface and take it to an external viewer. Is there any method enable this..?
Alberto_R_Intel
SACHINKV, Thank you for posting in the Intel® Communities Support.
I just transfer your case to the proper department. They will further assist you with this matter as soon as possible.
Albert R.
JonWay_C_Intel
Hi there, the LDPC acceleration is a lookaside acceleration via PCIe (not the ethernet).
The encoded data are streamed back to the host memory via PCIe. As it is processed realtime, it wont be fast enough to print the results. If you are looking to run a sanity test. I would suggest that you perform the DPDK bbdevtest : https://doc.dpdk.org/guides/tools/testbbdev.html
SACHINKV
Hi JonWay,
We are able to run the various testcases using the testbbdev app. But we are still looking for a way to atleast dump the encoded/decoded data and analyze the same later in some other tools like matlab. Thanks.
JonWay_C_Intel
Testbbdev compares the hardware output vs the reference output in the test_vector.
If you want to know the expected output, you can refer to the test_vector's output.
SACHINKV
We want to get the actual ouput from the encoder/decoder for further analysis
JonWay_C_Intel
You can modify the test_bbdev_perf.c...add printf to print the output.
