Hello
I have a warning Tcl Script name File .qip not found. How suppress this message? Thank you.Link Copied
You shouldn't suppress error messages like that. You need to find out what is causing them and correct the situation.
.qip refers to a Qsys component so you need to check if the original design includes one, and if there is a need to regenerate it
Thank you for your replys.
I didn’t see that my file.qip was added into my project twice with different paths. And thanks again.
