21602 Discussions
The parallel flash loader cannot see the flash device
GBusl
I have a flash device with NIOS using MAX10, I am sure the design is correct but cannot see the flash after programming the FPGA with pfl.sof and pressing Auto detect.
Ahmed_H_Intel1
Hi Galio,
I see you are working now with a flash device connected to MAX 10 correct?
Yes the "Parallel flash loader" is a way to program the flash device. You can find the required info here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
If you still cannot detect the flash, please let me know which flash device you are using. If it is an active serial like EPCQA, the PFL won't be able to detect it and you have to use the SFL "Serial flash loader". you can find the required info here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an370.pdf
Ahmed_H_Intel1
Hi Galio,
GBusl
Thanks a lot for your response. I now understood why it cannot see the EPCQA flash. Actually I am using Cyclone V now.
