Programmable Devices
21099 Discussions
Thermal Model for Arria 10 10AS057H3F34I2SG
Ziggy
I am looking for a Flotherm compatible thermal model for the Arria 10 10AS057H3F34I2SG.
EngWei_O_Intel
Hi Philip
Attached is the only Flotherm Compatible model of the this package that is available from Engineering. It is a Delphi model and not a compact model similar to what is available for Stratix 10. However, the thermal results should be sufficient since Aria 10 is a single die device.
Eng Wei
EngWei_O_Intel
Hi Philip
Link below is the official release of the location where FloTHERM Models reside.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd12102012_297.html
But I don't see any A10 model is available. I would need to check further before coming back to you.
Eng Wei
Ziggy
Hi Eng Wei,
Thanks for the reply and looking into this. If you can find out if there is an A10 model available that would be appreciated.
EngWei_O_Intel
Hi Philip
Eng Wei
Ziggy
EngWei_O_Intel
Hi Philip
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
You can help to set closure to this case if there is no further issue.
Thank you.
Eng Wei
