21592 Discussions
Timing Simulation error in Quartus prime 16.1
I wanted to run timing simulation for a multiplier i designed. However after successful functional simulation, the tool is giving an error while running timing simulation i.e:# ** Error (suppressible): (vsim-SDF-3196) Failed to find SDF file "Karatsuba_vhd.sdo".
# vsim -novopt -c -t 1ps -sdfmax Karatsuba_vhd_vec_tst/i1=Karatsuba_vhd.sdo -L cyclonev -L altera -L altera_mf -L 220model -L sgate -L altera_lnsim work.Karatsuba_vhd_vec_tst
# Error loading design
Please let me know what can be done.
From the Error message it looks like you are missing the .sdo file.
What device are you targeting ?
Gate-level timing simulation is supported only for the Arria II GX/GZ,Cyclone IV, MAX
II, MAX V, and Stratix IV device families.. Use Timing Analyzer static timing analysis
rather than gate-level timing simulation.
Ref:
https://www.altera.com/en_us/pdfs/literature/hb/qts/qts-qps-handbook.pdf
Page 1466
arslanusman2003
(This message was posted on behalf of Intel Corporation)
