21611 Discussions
Timing constraints to asynchronous output
SK_VA
I have outputs from one FPGA to another FPGA. Outputs are clocked out of one FPGA and is completely combinational in the other FPGA. Can I set false path to these outputs.
a_x_h_75
New Contributor III
Yes. Set false paths to any input or output signals that you don't need the timing analyser to consider.
Cheers,
Alex
SK_VA
Hi Thanks for the Reply.
How can we determine the signals that doesn't require timing analysis?
a_x_h_75
New Contributor III
Any signal in to or out of the device that is asynchronous - i.e. doesn't have an associated clock.
Cheers,
Alex
SK_VA
