hello
i want to do a transceiver using QUARTUS 17.1 but i couldn't merge TX and RX pin in the same BlockLink Copied
Can you elaborate on below points 1.Are you using any IP ? Can you name it? 2.Do you want to do loop back test? 3.Which device are you using? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- Mark as New
i'm using stratix10. and i'm using stratix 10 L-tile/h-tile transceiver native phy ip
i found this solution in the guideline
" set_instance_assignment -name XCVR_RECONFIG_GROUP 1 –to tx[0] • set_instance_assignment -name XCVR_RECONFIG_GROUP 0 –to rx[0] " but i dindn't know where i put thi solution in the design- Mark as New
It is a TCL Command. check the below link Check page 56:https://www.altera.com/en_us/pdfs/literature/hb/qts/qts_qii52001.pdf https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/mnl_qsf_reference.... http://quartushelp.altera.com/15.0/mergedprojects/tafs/tafs/tcl_pkg_project_ui_ver_1.0_cmd_set_insta... Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- Mark as New
ok i will check thank you
