20688 Discussions
Triple Speed Ethernet using DE2-115
I am a beginner at using the DE2-115 board. I have completed the "Using Triple-Speed Ethernet on DE2-115 Boards" tutorial but it doesn't seem to work.
The .sof file doesn't seem to be generated. Is there any alternate method to make it work or any tips you think may help solve this problem? Any advice would be very helpful.
Kind regards,
Elvis
Which version of the tool are you using do you have a license?
Check the link below which describes the same issue.
https://alteraforum.com/forum/showthread.php?t=39463&page=2
https://alteraforum.com/forum/showthread.php?t=49312
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
I'm using Quartus Prime Lite 16.1. Would there be any issues using this version? There are no errors displayed to do with the license as I see in the threads you shared. Could there be a similar tutorial or design example for the DE2-115 FPGA board using the Triple Speed Ethernet Megacore and the Ethernet transceivers?
Kind regards,
Elvis
Check the below link
https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-tse-sgdma.html
Anand Raj Shankar
