21602 Discussions
Trouble in Flashing to eMMC using USB blaster
Hi All,
We are trying flash the binaries to eMMC using USB-Blaster II
When I executed the below command it ends up with errors:
./flash_programmer.py --operation=epv --address=0x00000000 --size=0x00100000 --file=<path>/uboot_w_dtb-mkpimage.bin
(refered as in link https://rocketboards.org/foswiki/documentation/a10gsrd161nandboot?validation_key=d0d54f947c8f6494547938d664df12c1
Debug messages:
Launching debug server [0%]
[target] Starting debug server
[target] Waiting for debug server to start accepting connections
[target] Debug server started successfully
[target]
Launching debug server [100%]
[target] ERROR failed to connect to RDDI DAP target
[target] RDDI Error Code 4107 : Failed to load JTAG client library "libjtag_client.so"
[target] RDDI CFG = /tmp/ds5_1842063425346091758.txt
[target] Debug server shutdown application
[target] Debug server shutdown attempted
[target] Done
WARNING(DTS255): Failed to power down DAP
ERROR(TAD290-DTS77-DTS1-NAL57):
! Failed to connect to platform TCP:localhost
! Unable to connect to TCP:localhost
! Unable to connect to device DAP
! No connection to target.
INFO : WARNING(DTS255): Failed to power down DAP
ERROR: Launching debug server [0%]
[target]
[target] Done
What could have caused this error? Has anyone faced the same problem before??
Thank you.
Ambika
