21256 Discussions
UArt pins in Stratix v
ABDU11
Hi
I am using a Stratix V and I need, for my VHDL design, the RX and TX signals from UART.
However i found the RX in serial pins and the FPGA received well.
The problem is i couldn't find the TX pin can anyone help ?
Thank you.
Farabi
Hello, did you check the device pinout file? can you find the TX/RX pin there?
regards,
Farabi
AqidAyman_Intel
You can refer to below link to download the pin out file. Please ensure that you download the document for the device that you are using.
Pin-Out Files for Intel Field Programmable Gate Arrays (FPGAs) | Intel
Aqid
AqidAyman_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
