21615 Discussions
Unable to launch modelsim from quartus
High, can anyone tell me how to launch modelsim form quartus. I am getting following error when i tried to launch it??? how to remove this error???
You need to add the correct path to Tools>Options>EDA Tool Options.
I have C:\altera\14.1\modelsim_ase\win32aloem in ModelSim-Altera. You probably need the same, if you are using the Web edition.
--- Quote Start ---
--- Quote End ---
I have this setting in my quartus...
C:\altera\13.1\modelsim_ase\win32aloem
I am using web base edition 13.1...I have even read out the manual "Getting Started with Quartus II Simulation Using the
ModelSim-Altera Software" but I am receiving the same error
Have you actually got ModelSim installed at that location?
Are you able to open modelsim executable in C:\altera\13.1\modelsim_ase\win32aloem\modelsim.exe?
the extra slash there might make a different for old version of Quartus II
I use the Quartus II ver. 15.0.0.0 web edition on Linux.
When I select "Run simulation tool", display the dialog and can not launch modelsim.
