21345 Discussions
Unwanted inference of RAMs
I am working with an SOPC system design that includes a custom UART component. In the VHDL design of this component, I specify a memory using:
type fifo_type is array (0 to NUMWORDS-1) of std_logic_vector(0 to FIFO_WIDTH-1);
signal fifo_sig : fifo_type;
Up until know, it is OK that the tool places this into an M4K RAM block. However, at this point I need to implment this as registers instead of RAM - the RAM is needed for other memories. Within the context of my SOPC design, I have tried both project settings and attributes to try and prevent the RAM from being used. But the system always grabs this and puts into a RAM.
This does not work in my SOPC system:
attribute ramstyle : string;
attribute ramstyle of fifo_sig : signal is "logic";
So in contrast, if I create a small project that consists only of my VHDL, I can use both the attributes and the global quartus settings to prevent a RAM from being used.
WHY is this happening?
Kevin
Apparently, fifo_sig isn't the correct instance name or you're not in the correct hierarchy scope. Did you try to adjust global RAM inference synthesis rules?
Try sticking an async reset on fifo_sig - that behaviour is not allowed in RAMs so it will have to place registers.
I have tried to the global synthesis rules. If my UART is its own project, the global settings work, as do the attribute statements. When the UART is taken as a component within the SOPC, these things no longer work.
within the VHDL that instantiates the memory, fifo_sig is the correct name.
here is an exerpt from the fitter report (reformatted) when the RAM is extracted:
|UART_TOP:UART_TOP_0| --> |fifo_sync:FIFO_SYNC_RX| --> |altsyncram:fifo_sig_rtl_0| --> |altsyncram_iog1:auto_generated| --> M4Ks = 1
quite confused now. added the async reset and get the same results. M4K.
Post up your code. Adding an async reset that is tied low might have been removed during synthesis. Could you tie it to a real reset?
the code. comments are in italian, sorry. i am working with the design of my colleagues from Italy.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_signed.ALL;
USE ieee.numeric_std.all;
entity fifo_sync is
generic(
NUMBIT : integer; -- numero di bit dimensione
FIFO_FULL_PROTECTION : integer; -- margine in scrittura
FIFO_WIDTH : integer -- profondità dati
port(
clk : in std_logic;
reset : in std_logic;
data : in std_logic_vector (0 to FIFO_WIDTH-1);
rdreq : in std_logic;
wrreq : in std_logic;
q : out std_logic_vector(0 to FIFO_WIDTH-1);
empty : out std_logic;
full : out std_logic;
flush : in std_logic);
end fifo_sync;
architecture Behavioral of fifo_sync is
-- Impiegati per realizzare una FIFO di dimensione di potenza di 2
type lut_type is array (integer range 0 to 8) of integer range 0 to 256;
constant lut_square : lut_type :=(0, 2, 4, 8, 16, 32, 64, 128, 256);
-- Numero words FIFO
constant NUMWORDS : integer := lut_square(NUMBIT);
-- Dati accessibili con controllo FIFO FULL PROTECTION
constant numwords_ffp : integer := (NUMWORDS - FIFO_FULL_PROTECTION)-1;
-- Indirizzi per lettura e scrittura
signal addr_wr : std_logic_vector(0 to NUMBIT-1);
signal addr_rd : std_logic_vector(0 to NUMBIT-1);
-- Numero di dati presenti in FIFO
signal data_count : std_logic_vector(0 to NUMBIT-1);
-- Segnali FIFO FULL e EMPTY
signal full_sig : std_logic;
signal empty_sig : std_logic;
-- Abilitazione scrittura e lettura
signal wr_en : std_logic;
signal rd_en : std_logic;
-- knw 2/14/11
begin
full <= full_sig;
empty <= empty_sig;
-- Abilito la scrittura solo se la fifo non è piena
wr_en <= wrreq and (not full_sig);
-- Abilito la lettura solo se la fifo non è vuota
rd_en <= rdreq and (not empty_sig);
-- Gestione scrittura e lettura FIFO
PROC_FIFO: process ( clk, reset )
begin
if (reset = '1') then
for x in 0 to (NUMWORDS-1) loop
fifo_sig(x) <= (others => '0');
end loop;
elsif (clk'event and clk = '1')then
if(wr_en = '1')then
fifo_sig(TO_INTEGER(unsigned(addr_wr)))<= data;
end if;
q <= fifo_sig(TO_INTEGER(unsigned(addr_rd)));
end if;
end process PROC_FIFO;
-- Calcolo degli indirizzi per lettura, scrittura e numero di dati in FIFO
-- ad un accesso in scrittura incremento il conteggio dei dati presenti "data_count"
-- e incremento l'indirizzo per scrivere nella prossima locazione, in lettura
-- decremento il conteggio dei dati e incremento l'indirizzo per leggere la locazione
-- successiva
PROC_CNT_DATA: process ( clk, reset )
begin
if (reset = '1')then
data_count <= (others => '0');
addr_rd <= (others => '0');
addr_wr <= (others => '0');
if (flush = '1') then
elsif ((wr_en = '1') and (rd_en = '1')) then
data_count <= data_count; -- incremento e decremento -> conteggio invariato
addr_rd <= addr_rd + 1;
addr_wr <= addr_wr + 1;
elsif (rd_en = '1') then
data_count <= data_count - 1;
elsif (wr_en = '1') then -- empty
data_count <= data_count + 1;
end if;
end if;
end process PROC_CNT_DATA;
-- Gestione dei segnali full e empty
begin
full_sig <= '0';
empty_sig <= '1';
if(TO_INTEGER(unsigned(data_count)) = 0)then
empty_sig <= '1';
full_sig <= '0';
elsif(TO_INTEGER(unsigned(data_count)) >= numwords_ffp )then
full_sig <= '1';
empty_sig <= '0';
else
full_sig <= '0';
empty_sig <= '0';
end if;
end if;
end process;
end Behavioral;
Can you use code tags next time you post code please :)
I compiled it with and without a reset. I get an M4K (I used a Cyclone 1) with no reset and logic when there is a reset. When I made a reset signal stuck at '0', it also placed an M4K, so I can only assume your reset is set to '0'.
Thakns for the feedback. I mentioned above that using this code alone as it's own project, I can get logic or M4K as I prefer. But this logic is part of a component created for SOPC builder. Regardless of what I do to the logic at this level, I compile my desing (build SOPC system first) and get the M4K. This is why I am stumped.
Apologies, had not posted code before.
Kevin
