Hi Community,
I have a question about using SPI and I2C with the MAX10. There are no dedicated pins for SPI and I2C on the MAX10 pin description. Does that mean I can decide which pins I want to use for this? It will be a simple answered question for you but I'm not sure about this. Thanks in advance JérômeLink Copied
Hi Jérôme,
there are not any hardened I2C/SPI blocks in MAX 10. Therefore no dedicated pins exist for these protocols and it is necessary to implement it in FPGA. Best regards, Martin- Mark as New
Yes, you can use any of the standard I/O pins for connecting to SPI and/or I2C compatible devices.
Cheers, Alex- Mark as New
Thanks mbenca and a_x_h_75 for your replies.
Best Regards Jérôme
Topic Options
