20253 Discussions
VCXO replacement AN 746
FPaol1
I would like to know if the design can be applied to Stratix 5 also
CheePin_C_Intel
Hi, I would like to apologize for the delay in response. It seems like I encounter some issues with notification reaching my mailbox. Sorry for the inconvenience. As I understand it, you have some inquiries related to the A10 triple rate SDI example design. For your information, the AN746 design is only applicable to A10 devices. For SV devices, you may refer to the following example design at Design Store: https://fpgacloud.intel.com/devstore/platform/14.1/Standard/triple-rate-sdi-ii-reference-design-for-stratix-v-arria-v-and-cyclone-v-devices/ Please let me know if there is any concern. Thank you. Best regards, Chee Pin
FPaol1
Thanks for the reply, in the meantime i found AN-673 Serial Digital Interface II Reference
Design for Stratix V Devices and the relative design file for Quartus 12.
The file you linked is more recent, it is referred to the same Application note (i can't find any documentation in you linked page)?
 I would like to do the VCXO replacement design.​
CheePin_C_Intel
Hi, For your information, you may refer to the following link for the details on running the design. Seems like the information is written into a wiki page instead of a document. You may find the hyperlink in the Design Store page under documentation, somewhere in the middle. https://fpgawiki.intel.com/wiki/Triple-rate_SDI_II_Reference_Design_for_Stratix_V,_Arria_V_%26_Cyclone_V_devices Best regards, Chee Pin
CheePin_C_Intel
Hi, As I look through the Design Store, it seems like there is no specific example design on VCXO replacement for SV devices. Sorry for the inconvenience. Best regards, Chee Pin
