Hello, i have two modules sending signal to each other, one module has the following code
when WAIT_REQ_DATA =>
-- Wait for a requisition from the Goertzel module
if req_data = '1' then
calibration_state_next <= ASK_DATA;
get_data_reg_next <= '1';
else
calibration_state_next <= WAIT_REQ_DATA;
end if;
while the other has this code when WAIT_ENABLE =>
get_sample_next <= '0';
if data_ready_i = '1' then
state_core_next <= LOOP_PRINCIPAL_P1;
else
state_core_next <= WAIT_ENABLE;
end if;
Everything seems ok and it works for 185 times... then it stops to work (when the data_ready_i goes to 1 my state doesnt change in the second module) I made a change in my code to this: when WAIT_ENABLE =>
else
end if;
And then we can see in the screenshot that in the 185th time my module needs the data_ready to be one for two clock pulses There is absolutely no sense on this... why would everything work for 185 times and then stop? I am in the right state working for the pulse and the pulse happens... any help is welcome
how do you generate data_ready_in.
if it is not generated on same clock you might get problems of delta delay or actual delay that is not visible in waveforms- Mark as New
Both modules are recieving the same clock input (50 mhz) directly from the pin.
Data_ready_in is an input that is connected in the get_data_reg_next from my second module
when INCREMENT =>
-- Increment signals for processing
data_output_reg_next <= acc_reg;
data_ready_reg_next <= '1';
and it goes to zero one state after..
It's like the IF isn't working, can't be more clear then IF IN = 1 change state
and the IF is going to one.. seriously- Mark as New
As such it is perplexing without knowing fullm picture. However I note the change occurs when get_sample gows low. Do you have any conditions apart from if somewhere up the process
Nope.
Well, i registed the input and everything works fine now but i shouldnt need to register the input..- Mark as New
how about posting the code and testbench?
Topic Options
