Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
VHDL/Modelsim bug?
Hello, i have two modules sending signal to each other, one module has the following code
when WAIT_REQ_DATA => -- Wait for a requisition from the Goertzel module if req_data = '1' then calibration_state_next <= ASK_DATA; get_data_reg_next <= '1'; else calibration_state_next <= WAIT_REQ_DATA; end if;
while the other has this code
when WAIT_ENABLE => get_sample_next <= '0'; if data_ready_i = '1' then state_core_next <= LOOP_PRINCIPAL_P1; else state_core_next <= WAIT_ENABLE; end if;
Everything seems ok and it works for 185 times... then it stops to work (when the data_ready_i goes to 1 my state doesnt change in the second module)
I made a change in my code to this:
when WAIT_ENABLE => if data_ready_i = '1' then get_sample_next <= '0'; state_core_next <= LOOP_PRINCIPAL_P1; else state_core_next <= WAIT_ENABLE; end if;
And then we can see in the screenshot that in the 185th time my module needs the data_ready to be one for two clock pulses
There is absolutely no sense on this... why would everything work for 185 times and then stop? I am in the right state working for the pulse and the pulse happens...
any help is welcome
Highlighted
Re: VHDL/Modelsim bug?
how do you generate data_ready_in.
if it is not generated on same clock you might get problems of delta delay or actual delay that is not visible in waveforms
Highlighted
Both modules are recieving the same clock input (50 mhz) directly from the pin.
Data_ready_in is an input that is connected in the get_data_reg_next from my second module
when INCREMENT => -- Increment signals for processing data_output_reg_next <= acc_reg; data_ready_reg_next <= '1';
and it goes to zero one state after..
Highlighted
It's like the IF isn't working, can't be more clear then IF IN = 1 change state
and the IF is going to one.. seriously
As such it is perplexing without knowing fullm picture. However I note the change occurs when get_sample gows low. Do you have any conditions apart from if somewhere up the process
Highlighted
Nope.
Well, i registed the input and everything works fine now but i shouldnt need to register the input..
Highlighted
how about posting the code and testbench?
