Programmable Devices
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
20594 Discussions
VHDL Port Mismatch Error
Hi Everyone,
I have defined a component in my VHDL Flash file as shown in the Capture 1 attachment.
And I have generated a Flash IP.
The Flash is instantiated as shown in Capture 2.
When I compile the code, it throws in an error saying:
Error (12012): Port direction mismatch for entity "Flash_intf:Flash_Interface_Program|Flash:Flash_inst" at port "flash_nwe". Upper entity is expecting "Input" pin while lower entity is using "Output" pin.
Can anyone please tell me why am I getting this port mismatch error?
Thank you
You don't show the upper-level (or top-level) ports, but usually write enable and the other control signals are outputs to a flash device, not inputs.
--- Quote Start ---
--- Quote End ---
Thank you for your reply.
But I am getting the same error for address as well. The Flash_address is input std_logic_vector of 23 bits.
But it still says
Error (12012): Port direction mismatch for entity "Flash_intf:Flash_Interface_Program|Flash:Flash_inst" at port "flash_addr". Upper entity is expecting "Input" pin while lower entity is using "Output" pin.
I don't think address is also output.
Can you suggest what might be going wrong with this parameter?
Thank you once again.
Of course address is an output. That's how you choose an address location on the flash to read or write.
Can you post your top-level ports?
Can you draw a block diagram of how you think everything is hooked up? It can helpmin understanding what is going on.
Thank you for replying. I was able to solve the problem. Thank you for your time.
Thank you for replying. I was able to solve the problem. Address has to be output like you said. Thank you for your time.
