21611 Discussions
[VHDL] 'else generate' is not supported ...
Hi All,
I'm receiving the following error during my code compilation:
(vcom-1440) Language feature ELSE GENERATE STATEMENT is not supported yet
From what Quartus version is this feature supported?
Here is my code:
gen_flr_cnt : if (tbl(i).sbit = flr_cnt or tbl(i).pbit = flr_cnt or tbl(i).ibit = flr_cnt) generate i_flr_cnt : entity work.flr_cnt generic map( TRSH =>FLR_CNT_TRSH ) port map( clk => clk, rstn => rstn, clr => cnt_clr, flr_in => bit_vec(i), flr_out => flr_cnt_res(i) ); else generate flr_cnt_res(i) <= '0'; end generate gen_flr_cnt;
Thank you!
You are ahead of vhdl standards. You can split generate into two sections:
if true generate
end generate;
if false generate
end generate;
I was under the impression that else generate had been supported for a while. What quartus version are you using.
I am a bit suspicious of your generate expression though. Is it really static?
--- Quote Start ---
if true generate
end generate;
if false generate
end generate;
--- Quote End ---
Vhdl 2008 supports if..else generate and case generate. Quartus has supported it since at least q15
http://quartushelp.altera.com/15.0/mergedprojects/hdl/vhdl/vhdl_list_2008_vhdl_support.htm
What quartus version are you using" - Quartus v16
I am a bit suspicious of your generate expression though. Is it really static?" - yes, all elements inside of 'if' are constants
Well if it's saying it's not supported, you'll have to use separate generate statements.
Actually I tried this sintax in another Quartus 16 and it passed there...
Any clue? In both the file was defined as VHDL-2008
How could it be?
Standard edition or Pro? I think it may be a Pro edition only feature.
Quartus SJ Standard Edition... What is "SJ"?
Your error says "vcom". Is the error from a simulation tool or Quartus?
Quartus ...
I've never seen a vcom error in Quartus. I have seen that in ModelSim. Can you print out the whole error message?
it seems it was an error from ModelSim of Quartus...
Is it possible that Quartus's ModelSim (ModelSim AE) doesn't support this syntax while the Quartus itself (compile+filler+placement+...) does support it?
I'm just right away from my PC now...
It is very possible. Modelsim has much greater 2008 support, but if/else and case generate was oddly one thing they have only more recently supported.
do you compile with the -2008 flag?
"do you compile with the -2008 flag?" - yes ....
Can you find out which version of ModelSim are you using . The VHDL 2008 syntax is fully supported from the 10.3b release. If you have a pre 10.3b release, it will not support the VHDL2008 full syntax.
-Abr
I don't know which Modelsim version is bundled with Quartus V16, but V15 comes with 10.3d, so V16 is either the same or newer.
Reviewing the previous discussion and misleading reports about a Quartus problem, I'm not sure if dmitryl realizes that Modelsim has it's own VHDL version options, unrelated to the Quartus analysis and synthesis settings.
