Hi all,
I've a problem in VHDL. This code runs correctly:
library IEEE;
use IEEE.std_logic_1164.all;
entity CLOCK_SIM is
generic
constant FREQ : integer:=10000000;
constant DUTY : integer:=50
port
enable : in STD_LOGIC;
output : out STD_LOGIC
end CLOCK_SIM;
architecture CLOCK_SIM_ARCH of CLOCK_SIM is
begin
-- Processo principale
MainProcess : process
constant RDUTY : real:=real(DUTY)/100.0;
constant TCLKH : time:=1 sec*((1.0/real(FREQ))*RDUTY);
constant TCLKL : time:=1 sec*((1.0/real(FREQ))*(1.0-RDUTY));
begin
if enable='1' then
output<='1';
wait for TCLKH;
output<='0';
wait for TCLKL;
else
wait until enable='1';
end if;
end process MainProcess;
end CLOCK_SIM_ARCH;
but if I make a constant like an input:
library IEEE;
entity pwm_DC is
generic
--constant FREQ : integer:=1000000;
port
f : in integer;
end pwm_DC;
architecture pwm_DC_arch of pwm_DC is
signal FREQ : integer;
begin
FREQ <= f;
begin
if enable='1' then
output<='1';
wait for TCLKH;
output<='0';
wait for TCLKL;
else
end if;
end pwm_DC_arch;
this is the error: # ** error: (vsim-3601) iteration limit reached at time 7 us. Can anyone help me?
You have two constants (tclkh and tclkl) that will depend on the value of a signal 'freq' which in turn depends on the value of another signal 'f'.
Fix that up by changing those two constants to signals and give it another go...a calculated constant can't depend on a signal, since a signal is not 'constant' Kevin Jennings- Mark as New
Hi Kevin,
thanks a lot for your help. I just don't know how to do this. I have to change the 2 constants constant FREQ constant DUTY into two input signals. By these 2 signals, I can calculate these 2 values TCLKH TCLKL which I use to generate the output signal, a square wave with a duty cycle that depends on my two input values. Can you help me?- Mark as New
change TCLKH and TCLKL to signals or variables, and calculate their value at runtime, rather than at elaboration time. Currently, they use the initial value of FREQ, which will be -2^31.
Hi TRicky,
thanks to your help I solved the problem. Here's the simple code:
library IEEE;
entity pwm_DC is
port
f : in real;
d : in real;
end pwm_DC;
begin
-- Processo principale: generazione Duty Cycle
variable FREQ : real;
variable DUTY : real;
variable RDUTY : real;
variable TCLKH : time;
variable TCLKL : time;
begin
FREQ := f;
DUTY := d;
RDUTY := DUTY/100.0;
TCLKH := 1 sec*((1.0/FREQ)*RDUTY);
TCLKL := 1 sec*((1.0/FREQ)*(1.0-RDUTY));
output<='1';
wait for TCLKH;
output<='0';
wait for TCLKL;
end pwm_DC_arch;
