21611 Discussions
Verilog HDL coding of "Clock divider by 3"
Hi. I'm "720_com" of Altera beginner.
I want to create about verilog HDL coding of Clock divider by 3.
I make Clock divider by 3
Input Frequency : 75MHz
Output Frequency : 25MHz
module divide3_check(reset_n, clkin, clkout, ng);
input reset_n;
input clkin;
output clkout;
output ng;
reg[1:0] counter_pos = 2'd0;
reg[1:0] counter_neg = 2'd0;
always @(posedge clkin or negedge reset_n)
begin
if (~reset_n)
counter_pos <= 2'd1;
else if (counter_pos==2'd3)
else
counter_pos <= counter_pos + 2'd1;
end
always @(negedge clkin or negedge reset_n)
begin
if (~reset_n)
counter_neg <= 2'd1;
else if (counter_neg==2'd3)
else
counter_neg <= counter_neg + 2'd1;
end
assign clkout = ((counter_pos != 2'd3) && (counter_neg != 2'd3));
reg[1:0] counter_neg_reg = 2'd0;
begin
if (~reset_n)
counter_neg_reg <= 2'd1;
counter_neg_reg <= counter_neg;
else
counter_neg_reg <= counter_neg_reg;
end
reg ng = 1'd0;
begin
if (~reset_n)
ng <= 1'd0;
ng <= (counter_neg_reg != counter_neg);
else
ng <= 1'd0;
end
endmodule
Please show you "rtlsim.png" and "gatesim.png".
rtlsim.png -> RTL Simulation
gatesim.png -> Gate level simulation
The both simulation result "clkout : 25MHz".
But, Internal signal waveform is difficult.
Please tell me if there is a mistake in my description.
The problem here is that you are using counters to create logic. it is going to give terrible results (bad results made even worse by the fact your output is the output of logic, not a register).
You should create a clock enable using a single clock. Then everything is on the same clock domain and you wont have any problems related to timing, temperature, voltage and process that you will have with your current implementation.
