21324 Discussions
Very simple Verilog code, but not working on DE2
I am running this simple code, pushing KEY[3] works fine (decrement), but when I push KEY[1] the 7-seg changes with both pushing and releasing and display some random number on the 7-seg.
hex_7seg is just a module to display count on the 7-seg. It works fine for other projects.
Looks like the problem is with the if statement. Since when I test KEY[3] instead of KEY[1], the problem will be when I push KEY[3]
Any help is appreciated
module d1_7seg(KEY, HEX0);
input [3:0] KEY;
output [6:0] HEX0;
reg [3:0] count;
always @ ( negedge KEY[3] or negedge KEY[1])
begin
if(KEY[1] == 0)
begin
count <= count + 1;
end
else
begin
count <= count - 1;
end
end
hex_7seg (count, HEX0);
endmodule
As a simple fact, you can't have two different edge sensitive triggers for a single counter.
The code actually defines an edge sensitive (synchronous) trigger for KEY[3] and an asynchronous trigger for KEY[1], which doesn't work for a counter. The combination of negedge KEY[1] and if (KEY[1] == 0) is a specific Verilog syntax, that's e.g. used for asynchronous resets. You typically should get a serious synthesis warning like "count[x] doesn't hold it's state between clock edges" indicating, that the counter doesn't work.
Facing this fact, you obviously need to use a different method to detect keypress events. The common method is synchronous edge detection utilizing a system clock and comparing present and previous state of a signal.
First, thanks. You are right. It works now.
However, I thought that
always @ (negedge KEY[3] or negedge KEY[1] )
if (KEY[1] == 0)
is similar to
always @ (posedge clock or negedge RST)
if (RST == 0)
which works fine
I guess I was wrong ...
Thanks again
--Mokhtar
The RST example creates asynchronous logic, as said. You'll never be able to e.g count reset events under the (RST == 0) condition.
