20404 Discussions
Voltage supported by EPM7032LC44-10
Developer_123
I would like to know whether EPM7032LC44-10 supports 5V as supply voltage?
In datasheet it was mentioned that 3.3-V or 2.5-V power supply can be used. It is also mentioned that the device can be set for 2.5-V, 3.3-V, or 5.0-V I/O pin operation.
ak6dn
Valued Contributor III
Your part number reference is for the original MAX 7000 series, which is 5.0V core and I/O only.
It does NOT support 3.3V or lower I/O voltage levels.
OTOH the MAX 7000B series has multivolt I/O capability, and can support 3.3V, 2.5V, or 1.8V I/O using the VCCIO pin connection.
It does NOT directly support 5.0V I/O however, max VIN is something like 4.6V.
Maybe you are asking about the MAX 7000A series. It has multivolt I/O that can support 5.0V, 3.3V, or 2.5V operation using VCCIO.
So if you are asking about EPM7032ALC44-10 instead then the answer is yes it can support 5.0V I/O.
ak6dn
Fakhrul
Thank you ak6dn for the answer provided.
Hi Developer_123.
You may refer to the answer mentioned by ak6dn above.
Do you have any further questions on this matter?
Please feel free to let me know if there is any concern so that we could further assist you.
Fakhrul
Fakhrul
Hi Developer_123,
As we do not receive any response from you to the previous answer that have been provided.
This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you.
