21594 Diskussionen
WHY there're 2 addtional Brdiges between "PCIE Hard Code IP" and " EMIF DDR4 IP" in pcie desig ?
JET60200
Neuer Beitragender I
1.050Aufrufe
I have a technical question regarding of "pcie avmm -> ddr4" logic path in "QSYS Interconnection".
When checking customer's PCIE AVMM Design for A10, I find their "PCIE -> DDR4" data path follows as below picture : pcie_ddr4_ep_g3x8_avmm256.png
This is a PCIe gen3x8 AVMM example case in A10SOC. my personal understanding is :
  • the "PCIE Hard IP core 's -> dma_rd(wr)_master" can connect to " emif_ddr4 's slave". that can satisfy the design.
WHY in customer's design, they insert two adstional Brdiges between PCIE Hard Code IP aand the EMIF DDR4 IP ?
the inserted two bridge are in picture :
"mm_clock_crossing_bridge_ddr4_a",
" pipe_stage_ddr4a_dimm " ?
I just wonder why they exist in here ? ANyone has explanation ?
4 Antworten
sstrell
Geehrter Beitragender III
1.023Aufrufe
You are correct. In most cases, you don't need to manually add bridges to a design like this. Clock crossing logic is added automatically to the interconnect when the system is generated. However, you may want to add a bridge manually like this for more control over how the clock crossing is implemented. As for the pipeline bridge, that is used to adjust the topology of a system (for example, aggregate multiple exported interfaces into one) or add pipeline stages to improve performance.
So the short answer is that these bridges are optional.
#iwork4intel
JET60200
1.023Aufrufe
Thanks @sstrell​  for detailed clarification.
Regarding of "Quartus Automatic Adding the internal bridge" vs "Customer defines the defined bridge", how could we compare and evaluate their performance difference, to decide which one to be used ? Do you have any idea ?
Thanks a lot ​
BoonT_Intel
1.023Aufrufe
Hi Sir,
From performance perspective, usually without the bridge is the best because the latency is decrease. The bridge is add for some other purpose like both master-slave clock use different clock domain, multiple master to single slave or vice versa. You may refer to the description of the bridge as explain in this document, all bridge added is for some purpose.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/edh_ed51007.pdf
BoonT_Intel
1.020Aufrufe
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Antworten
