21610 Discussions
WYSIWYG documentation
HMai
Is there documentation available for the WYSIWYG components (eg twentynm_clkena, twentynm_ddio_out)?  If not, where can one find the verilog source?
Hung
ventt
Can you try using this path and see?
quartus/libraries/megafunctions/xml_info/twentynm_clkena_info.xml
Because I managed to open it at my end.
Ven Ting
ventt
We do not provide documentation for WYSIWYG components.
You may checkout the Intel® Quartus® Prime Pro and Standard Software User Guides if it helps.
https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/user-guides.html
Ven Ting
HMai
Thanks, where can I look at the HDL to check IO information such as parameters and port names?
Hung
ventt
You may go to File > Open in Quartus and search for e.g. twentynm_clkena in the directory where you installed the Quartus.
Ven Ting
HMai
Ven Ting,
Search for *twentynm_clkena* does not return any results
Search for *twentynm" returns some files (below) but none has the twentynm_clka component.
    twentynm_io_12_lane_*
    twentynm_xcvr_*
    twentynm_pma.sv
    twentynm_pcs.sv
Tool used is Quartus Prime Pro Version 22.1.0 Build 174 03/30/2022 SC Pro Edition for windows.  Please send more ideas.
Hung
ventt
Ven Ting
ventt
Attached with the screenshot of twentynm_clkena_info.xml.
HMai
Thanks Ven Ting, twentynm_ component parameters and ports are available at this location.
Hung
ventt
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Ven Ting
