20882 Discussions
Warning (287001): Assertion warning: Device family MAX10 does not have MLAB blocks -- using available memory blocks
XQSHEN
Device: 10M16DCU324I7G
Design : NIOS + UNIPHY for DDR2
Below warning is generated when synthesis. I don't understand the problem and action required.
Kenny_Tan
This warning means that Max 10 does not have MLAB blocks, it got only M9k blocks https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_overview.pdf page 11.
You don't need to do anythings, Quartus will auto assign to other memory blocks since this device do not have MLAB blocks.
XQSHEN
But I don't specify anywhere using MLAB blocks, and Quartus also should know Max10 resources. Why such warning come up?
Kenny_Tan
That will need to investigate. Can you attached your design.qar here? Or you can email to us privately. You may check your email.
Kenny_Tan
Kindly take note this will be handle internally.
Kenny_Tan
This thread had been resolve internally, it had been set to closed.
After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
