What does this pu1 of the clk means in the modelsim-altera ?
The verilog codes of the cam in the cookbook (http://www.altera.com/literature/manual/stx_cookbook.pdf). There's 5 files: ram_block.v ram_based_cam_tb.v ram_based_cam.v cam_ram_block_tb.v cam_ram_block. All the files are compiled in the Quartus 11 successfully.The 2 testbench files (ram_based_cam_tb.v & cam_ram_block_tb.v) are also successful,but in the Modelsim 6.6 ,the waves are wrong, the "clk" is "pu1", what does this means? How to correct it ?Link Copied
"pu1" means pull up high. It's a state to model outputs with pull up resistors.
Are you simulating the correct file? You should be simulating one of the test benches (_tb).- Mark as New
