21470 Discussions
What happens when I/O is configured as BLVDS but VCCIO pin is fed by 3.3V?
REics
I have a design (already mass produced) where the VCCIO is fed with 3.3V, but I/Os on it are configured as BLVDS.
What happens? Does it damage the device? Does it just create an out of spec BLVDS output signal?
YuanLi_S_Intel
Hi Rolf,
May i know which device you are using? If is much recommended if you could supply the VCCIO needed for BLVDS.
Thank You.
REics
It's a EP4CE40F23C8N. I know it's not recommended and I won't deliberately do it, but I have a number of devices out in the field already and want to know what the effects of this are. My BLVDS signal looks ok and does what I want, the question is more I run the risk of damaging something. I have set the outputs to lowest current (8mA) as security measure, though.
YuanLi_S_Intel
The problem would be damage to I/O buffer. If it is exceeding the absolute maximum rating of VCCIO.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-iv/cyiv-53001.pdf (Page 2)
