20403 Discussions
What happens when the 1-port ROM exceeds the address?
sung_chul
Hi-
For example, in the following cases
data width = 8
data depth = 100
What is the value if you access address 101, 102  or  358... ?
mif file is below
CONTENT BEGIN
[0..99] : 00110011;
END;
Thanks!
Nurina
It will just be X value.
Do you have anymore concerns?
Nurina
Nurina
Thank you for using Intel Communities. Please allow some time while I investigate your problem.
Nurina
Nurina
Nurina
sung_chul
Nurina
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
