Programmable Devices
20679 Discussions
What is different EP4CE6F17C8N and EP4CE6F17C8NAD
duckseo
Hello
We used EP4CE6F17C8N without problem, but we used EP4CE6F17C8NAD mixed and had problems only with this product. So I want to know what's the difference between the two products
Thank you
JohnT_Intel
Both part is the same where the part with AD is a special requested part. May I know what is the issue that you are facing?
JohnT_Intel
duckseo
Thank you for the reply.
I understand both part is same. but this product is still not working
So I would like to know what this optional suffix means?
because I have to explain to my boss that the two products are the same
Thank you
duckseo
Hi
Thank you for your reply.
The picture above is the waveform of the nCSO pin during initial startup.
The left is GOOD, but right (AD) is NOT GOOD.
What do you think is the problem?
