21344 Discussions
What is wrong with this code?
LIBRARY altera;
USE altera.maxplus2.ALL;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY test IS
PORT
a, b, c, gn : IN STD_LOGIC;
d : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
y, wn : OUT STD_LOGIC
END test;
ARCHITECTURE a OF test IS
BEGIN
mux : a_74151b PORT MAP (c, b, a, d, gn, y, wn);
END a;
Warning: LMF mapping record a_74151b -> 74151b missing the "mux" port mapping(s) for node "mux"
Error: Node instance "mux" instantiates undefined entity "a_74151b"
Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 9 warnings
Error: Quartus II Full Compilation was unsuccessful. 1 error, 9 warnings
I use QuartusII 9.1 and port map a_74151 is ok.
LIBRARY altera;
LIBRARY ieee;
ENTITY test IS
PORT
END test;
BEGIN
mux : a_74151 PORT MAP (c, b, a, d(7),d(6),d(5),d(4),d(3),d(2),d(1),d(0), gn, y, wn);
END a;
You need to include the component declaration for the a_741151b entity, either through including the package its declared in, or creating the component declaration in the architecture "a".
If you use VHDL'93 coding standard you do not need to include a package or declare the component.
Just google for "VHDL'93 instantiation style"
