Hello
Since it became necessary to replace the EPCS device with the EPCQ-A device,
I need quartus-13.1.4-4.70r patch file, which supports EPCQ-A.
Where can i find the link for this file?
Best regards.
Seem current issue is related to embedded config, I suggest you to close this ticket and open a new case thread for a right owner support. Let me know if there is any concern.
Hi Sir,
Do you want the patch only or Quartus with patch?
Thank you for your reply.
I’m currently using version 13.1.4 build182(patch none).
I'm thinking of applying a patch to this, so I would like a patch file.
If the patch does not work, I will request Quartus with the patch.
Best regards.
I sent an email with the patches attached for Win/Linux. Let me know if you are not able to retrieve them.
Hello
I also want a patch file.
Would you please send it?
I am working on getting a patch for a 32 bit version of Quartus with version 13.1.4.182 already installed and patch 4.70r is not showing as installed in that 32 bit version. Any ideas?
Hi Intel Customer Support
Thank you for sending the file.
Thank you for helping me very much.
After applying the patch and in Convert Programming Files ... ,
I was able to confirm that the EPCQ-A device can be selected as the Configuration device and can be converted to a jic file.
But I have not solved everything yet.
Please tell me about the settings of Advanced options and saving the .cof file.
The settings are as follows.
Programming file type: JTAG Indirect Configuration File(.jic)
Configuration device: EPCQ128A
Mode: Active Serial
Advanced Options
checked Disable EPCS ID check
checked Disable AS mode CONF_DONE error check
Program length count adjustment: 0
Post-chain bitstream pad bytes: default
Post-device bitstream pad bytes: default
Bitslice padding value: 1
QSPI Flash Single IO mode dummy clock: Unchangeable
QSPI Flash quad IO mode summy clock: Unchangeable
QSPI Flash Single IO mode dummy clock:Unchangeable
Even if I save the .cof file with Save Conversion Setup ..., the Advanced Option part is not listed,
Is it used incorrectly?
Due to the above problem, I actually added the following to .cof file.
<cof>
<advanced_options>
<ignore_epcs_id_check>2</ignore_epcs_id_check>
<ignore_condone_check>2</ignore_condone_check>
<plc_adjustment>0</plc_adjustment>
<post_chain_bitstream_pad_bytes>-1</post_chain_bitstream_pad_bytes>
<post_device_bitstream_pad_bytes>-1</post_device_bitstream_pad_bytes>
<bitslice_pre_padding>1</bitslice_pre_padding>
</advanced_options>
</cof>
The above way of writing is supported to check "Disable EPCS ID check" and "Disable AS mode CONF_DONE error check"?
Also for reference, please tell me the values that can be set in <ignore_epcs_id_check> and <ignore_condone_check> and their meanings.
I got it.
The added question is different from this one, so I will set up another thread.
Thank you for your support.
