21416 Discussions
Where is Quartus 13.1.4 patch 4.70r
on0308
Hello
Since it became necessary to replace the EPCS device with the EPCQ-A device,
I need quartus-13.1.4-4.70r  patch file, which supports EPCQ-A.
Where can i find the link for this file?
Best regards.
SyafieqS
Seem current issue is related to embedded config, I suggest you to close this ticket and open a new case thread for a right owner support. Let me know if there is any concern.
SyafieqS
Hi Sir,
Do you want the patch only or Quartus with patch?
on0308
Thank you for your reply.
I’m currently using version 13.1.4 build182(patch none).
I'm thinking of applying a patch to this, so I would like a patch file.
If the patch does not work, I will request Quartus with the patch.
Best regards.
SyafieqS
I sent an email with the patches attached for Win/Linux. Let me know if you are not able to retrieve them.
wara
Hello
I also want a patch file.
Would you please send it?
Jeff17
I am working on getting a patch for a 32 bit version of Quartus with version 13.1.4.182 already installed and patch 4.70r is not showing as installed in that 32 bit version.  Any ideas?
on0308
Hi  Intel Customer Support
Thank you for sending the file.
Thank you for helping me very much.
After applying the patch and in Convert Programming Files ... ,
I was able to confirm that the EPCQ-A device can be selected as the Configuration device and can be converted to a jic file.
But I have not solved everything yet.
Please tell me about the settings of Advanced options and saving the .cof file.
The settings are as follows.
    Programming file type:  JTAG Indirect Configuration File(.jic)
    Configuration device:  EPCQ128A
    Mode:  Active Serial
    Advanced Options
        checked   Disable EPCS ID check
        checked   Disable AS mode CONF_DONE error check
        Program length count adjustment:  0
        Post-chain bitstream pad bytes:  default
        Post-device bitstream pad bytes:  default
        Bitslice padding value:  1
        QSPI Flash Single IO mode dummy clock:  Unchangeable
        QSPI Flash quad IO mode summy clock:  Unchangeable
        QSPI Flash Single IO mode dummy clock:Unchangeable
Even if I save the .cof file with Save Conversion Setup ..., the Advanced Option part is not listed,
Is it used incorrectly?
Due to the above problem, I actually added the following to .cof file.
<cof>
    <advanced_options>
        <ignore_epcs_id_check>2</ignore_epcs_id_check>
        <ignore_condone_check>2</ignore_condone_check>
        <plc_adjustment>0</plc_adjustment>
        <post_chain_bitstream_pad_bytes>-1</post_chain_bitstream_pad_bytes>
        <post_device_bitstream_pad_bytes>-1</post_device_bitstream_pad_bytes>
        <bitslice_pre_padding>1</bitslice_pre_padding>
    </advanced_options>
</cof>
The above way of writing is supported to check "Disable EPCS ID check" and "Disable AS mode CONF_DONE error check"?
Also for reference, please tell me the values ​​that can be set in <ignore_epcs_id_check> and <ignore_condone_check> and their meanings.
SyafieqS
on0308
I got it.
The added question is different from this one, so I will set up another thread.
Thank you for your support.
