A case was filed with Intel, refer to Case #:03999939
MFR: Altera
MPN: 5SGXMA4H3F35C4N
Defect: Missing solder ball
Rejected Qty: 1pc
Supplier: Macnica Cytech Pte Ltd
Comments: Intel/Altera insisted the manufacturing process is full proof unlikely to have such defect!! Why Intel/Altera is behaving so complacent and arrogant that not interested to find out more of the quality feedback? It's manufacturer's responsibility to provide failure analysis instead of negative response.
Currently I am reviewing the forum for any open questions and found this thread. I apologize that no one seems to answer this question that you posted. Since it has been a while you posted this question, I'm wondering if you have found the answer? If not, please let me know, I will try to assign/find someone to assist you. Please do expect some delay in response as most of our agents are out of office due to the year-end holidays. Thank you.
Nooraini
Hi Siew Ying,
We apologies for any inconvenient cause on you. From your description showed there is a missing ball issue observed on 5SGXMA4H3F35C4N.
For your information, Intel FPGA perform 100% Ball Scan prior to shipment, so it's unlikely that the device will have been shipped with a missing ball. There is a high possibility that it was damaged in transit or shipping or improper storage. We have ball scan and visual test. Plus, we have drop test proved packing. we test all devices for shorts and opens before the devices leave our factory. All our devices are fully tested as good before shipped to customer. The purpose of production testing during manufacturing is to screen out bad units and in the case of this case, short in circuit diagram. The purpose of production testing during manufacturing is to screen out bad units and in the case of this request, the missing solder ball would not pass the open/short test.
Intel FPGA Reliability Report had stated clearly that we perform comprehensive testing and manufacturing controls on all its products:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rr/rr.pdf
We could guarantee devices leave factory door in good condition. Once shipment leaves factory, we are no longer liable as it subjects to forwarder’s handling, distributor’s handling and customer’s handling. There is no way to tell if the damages are done before devices leave factory door. Therefore, no RMA will be proceed due to the missing ball issue reported.
You can look into this to come out some corrective action. Meanwhile, you may referring to the solution below on the maximum downward pressure that can be applied to the top of BGA
Thank you
Chia Ling
Hi Siew Ying,
As communicated, we have drop test proved packing. we test all devices for shorts and opens before the devices leave our factory. All our devices are fully tested as good before shipped to customer. There is no way to tell if the damages are done before devices leave factory door since we do not have the visibility on how customer handling the devices. Therefore, we would not proceed for part replacement. Appreciate much for your understanding.
Thank you
Chia Ling
Hi Siew Ying,
I apologies for the miss understanding. By referring to the Intel FPGA Failure Analysis Service - we test all devices for shorts and opens before the devices leave our factory. All our devices are fully tested as good before shipped to customer. The purpose of production testing during manufacturing is to screen out bad units:
We could guarantee devices leave factory door in good condition. Once shipment leaves factory, we are no longer liable as it subjects to forwarder’s handling, distributor’s handling and customer’s handling. There is no way to tell if the damages are done before devices leave factory door. Therefore, no failure analysis or part replacement will be proceed due to the missing ball issue reported.
Thank you
Chia Ling
