21607 Discussions
Why device has stopped receiving configuration data when programming?
Jiayi_H_Intel
I am initializing 2 Gen4x8 R-tile Pcie HIP(one is upstream/upstream, the other is downstream/downstream). Compilation using Quartus 21.2 passed successfully.
But when I try to program the sof file to device, programmer reports errors:
Error(18950): Device has stopped receiving configuration data
Error(18948): Error message received from device: Internal error. (Subcode 0x001A, Info 0x00000000, Location 0x00004400)
Error(22248): Detected an error during configuration. Refer to the Configuration User guide for details on debug guidelines. Check the latest Intel Quartus Prime software release for possible fixes.
Error(209012): Operation failed
Any ideas about it?
JohnT_Intel
Could you confirm if you are providing the refclk to the PCIe IP on your board?
You may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/agilex/ug-ag-config.pdf Chapter 7 on how to further debug the issue.
Jiayi_H_Intel
Here is the device I use: AGIB027R29A1E2VR0
And I am using these pins for ref clock:
For EP side:
refclk_pcie_14c_ch1_p(n) : CR70 : input : Current Mode Logic (CML) : 0V : 14C
refclk_pcie_14c_ch1_p : CU68 : input : Current Mode Logic (CML) : 0V : 14C
refclk_pcie_14c_ch0_p(n) : DM70 : input : Current Mode Logic (CML) : 0V : 14C
refclk_pcie_14c_ch0_p : DR68 : input : Current Mode Logic (CML) : 0V : 14C
For RP side:
refclk_pcie_rp_ch0_p(n) : FV26 : input : Current Mode Logic (CML) : 0V : 15A
refclk_pcie_rp_ch0_p : GA27 : input : Current Mode Logic (CML) : 0V : 15A
refclk_pcie_rp_ch1_p : GY26 : input : Current Mode Logic (CML) : 0V : 15A
refclk_pcie_rp_ch1_p(n) : HC27 : input : Current Mode Logic (CML) : 0V : 15A
Anything incorrect with my assignment?
JohnT_Intel
May I know if the refclk have a valid clock signal when you performed programming?
Jiayi_H_Intel
15A seems not work. After changing to 15C, it can be programmed. Thanks!
JohnT_Intel
It looks like there is no clock signal from 15A pin which cause the configuration to failed. Please let me know if you have any other queries.
JohnT_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
