Programmable Devices
20639 Discussions
Why does Striatix 10 -3 speed 's Fmax of ROM restricted on 420Mhz, But it is not described in Timequest report?
LChen23
Hi, expert
As Table 65. Memory Block Performance Specifications for Intel Stratix 10 Devices​ in Stratix 10 datasheet, the 'True dual port, all supported widths ' -E3V, performance is 420Mhz. But after timing analyzing in timequest , The report the Fmax summery is higher than 420Mhz , even could reach above 500Mhz .
so , my question is , which one should I trust, the 420Mhz in datasheet or 500Mhz+ in timequest report?
KhaiChein_Y_Intel
Can you provide the report?
KhaiChein_Y_Intel
May I know if you have any udpates?
LChen23
I find the reason, it seems the 900mV timming model report Fmax strict to 420Mhz. and VCCRAM is 900mV.
KhaiChein_Y_Intel
Do you have any questions?
