Hi, expert
As Table 65. Memory Block Performance Specifications for Intel Stratix 10 Devices in Stratix 10 datasheet, the 'True dual port, all supported widths ' -E3V, performance is 420Mhz. But after timing analyzing in timequest , The report the Fmax summery is higher than 420Mhz , even could reach above 500Mhz .
so , my question is , which one should I trust, the 420Mhz in datasheet or 500Mhz+ in timequest report?
Can you provide the report?
May I know if you have any udpates?
I find the reason, it seems the 900mV timming model report Fmax strict to 420Mhz. and VCCRAM is 900mV.
Do you have any questions?
Topic Options
