Working with LCD
Pardon how amateur this looks, I havent had much practice
Here is the code I wrote, as far as I can tell I've wired everything up as documented in the code, but when I try to run it, the bottom Blocks of the LCD go solid, like the other forums said should happen before it's initialized. But I see no response at the LCD. It may have looked neater if Freddy Krueger had soldered it, but I am pretty sure I didn't damage it.
This is a standrd LCD from sparkfun. I am working with the Cyclone II starter Kit, and I am a reformed Visual Basic Person, so thats why I seem to write code a little different.
Please tell me if anything you see would make this not work, or if you have any tips on how to do it more effeciently, I know it looks really amateur at this point.
module LCD_PRINT(IOBUS,deb2,clk,STC);
output [30:0] IOBUS;
// output pins
input [3:0] deb2;
//debounce signal, I step through this with the buttons so I can test signals
input clk;
// standard clock from starter board (27mhz)
reg [7:0] outc;
// 8 bits going out to data db0-db7
reg RS;
// register select
input [3:0] STC;
// STC count incremented from debounce, its on 7seg LCD for testing
reg [16:0] count;
// timer for leaving E high for a while, then shutting it
reg writing;
// reg for E on or off
// debounce comes as a pulse from another module
// this part generates my E writing signal to LCD
// Simulation seems to work
always@(posedge clk)
begin
if (deb2!=4'b0000 & count==0)
begin
count=1;
writing=0;
end
if (count>0 & count!=1000)
begin
count=count+1;
end
if (count>200 & count !=1000)
begin
writing=1;
end
if (count==1000)
begin
count=0;
writing=0;
end
//this segment sets output for each data sent, STC is count that is incrementd in the debounce module
if (STC==1)
begin
outc=8'b00111000;
// send 38h for 8 bit mode
RS=0;
end
if (STC==2)
begin
outc=8'b00001111;
// send 0Fh for "Display On"
RS=0;
end
if (STC==3)
begin
outc=8'b00000001;
// send 01h to clear
RS=0;
end
if (STC==4)
begin
outc=8'b00001111;
RS=1;
end
if (STC==5)
begin
outc=8'b01111111;
RS=1;
end
if (STC==6)
begin
outc=8'b11111111;
RS=1;
end
if (STC==7)
begin
outc=8'b01010101;
RS=1;
end
end
assign IOBUS[0]=0;
// IOBUS[0]=R/W always at 0 for writing
assign IOBUS[1]=RS;
// IOBUS[1]= RS 0 for command, 1 for data
assign IOBUS[2]=writing;
// IOBUS[2]=RE
assign IOBUS[3]=outc[0];
assign IOBUS[4]=outc[1];
assign IOBUS[5]=outc[2];
assign IOBUS[6]=outc[3];
assign IOBUS[7]=outc[4];
assign IOBUS[8]=outc[5];
assign IOBUS[9]=outc[6];
assign IOBUS[10]=outc[7];
endmodule
_________________
It's good to be evil
