The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
19680 Discussions
Would you recommend "new" Cyclone 10 GX now for a new design??
I have seen that Cyclone 10GX are being available. As they are comparable to the smallest & low grade A10GX, but for a much lower cost, they can be very interesting I think.
pro:
- Low price
- Some parts are stocked (36 pieces of 10cx220yf780i6g (https://www.buyaltera.com/partdetail?partid=7593617) and 10cx220yf780e6g (https://www.buyaltera.com/partdetail?partid=7595044))
- 1 dev kit available
cons:
- Less documentation than older FPGA (compare to A10GX for example)
- Almost no entry on Altera forum (+1 now :-) ) and only 1 on Altera wiki
- Only 1 dev kit with only the schematic pdf available. No Quartus ref design to prove tools/chips are working and have been tested (golden top, transceiver, BTS, …).
- Q17.1pro (no licence) is crashing a lot and compiling a former Q17.0standard A10GX project does not work (all ip re-created manually in Q17.1pro).
Analysis&Synthesis is stuck at 4%, then PC RAM grows till the max 32GB available and then SW ends.
But Altera wiki "simple" example compiles.
As I need several demanding features regarding tools (configuration, pinout and timing analysis), I am afraid that it is too soon to use cyclone 10GX.
- Several 12.5Gbps RX/TX
- >80LVDS inputs (serialize x10, ~1gbps)
- Remote update
what do you think? do you already design boards with c10gx?
Thanks for feedbacks.
links:
Dev kit:
https://www.altera.com/products/boards_and_kits/dev-kits/altera/cyclone-10-gx-development-kit.html?u...
Altera wiki project:
http://www.alterawiki.com/wiki/file:c10userconfigurabletransceiverdemodesign.zip
I'm no expert, but I'm going to wait until there are more parts available, more dev kits, more ref designs, etc. before I launch into a C10GX design.
Thanks for you answer !
I have the same reasoning but I was hopping to get an opposite one^^
