21611 Discussions
XAUI IP for Cyclone V SX
ochiang
I would like to know if it is feasible to use Cyclone V SX with XAUI IP (Soft PCS) to achieve 10Gbps Ethernet? Do you have any recommendations for external circuits? Can I use an external XAUI to SFI PHY to accomplish this project?
Additionally, I saw the DUAL XAUI TO SFP+ HSMC BOARD on Terasic. Its architecture seems to be what I want to achieve (FPGA <-> XAUI <-> BCM8727 <-> SFP), but it does not mention Cyclone V SX. Does this mean that Cyclone V SX cannot use XAUI IP to complete this task?
Thank you.
AR_A_Intel
Hi
Using Cyclone V SX with XAUI IP (Soft PCS) to achieve 10Gbps Ethernet is not directly supported, as Cyclone V SX does not natively support 10Gbps Ethernet. However, you can use an external PHY like Broadcom BCM8727 to handle the XAUI to SFI conversion, enabling 10Gbps Ethernet. The Terasic DUAL XAUI TO SFP+ HSMC BOARD can facilitate this architecture (FPGA <-> XAUI <-> BCM8727 <-> SFP), although it requires careful integration and validation.
For further details, refer to https://www.intel.com/content/www/us/en/products/details/fpga/intellectual-property/interface-protocols/10g-base-x-xaui-pcs.html
AR_A_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
