21592 Discussions
about Internal Weak Pull-Up(cyclone10LP)
M_Goto
Tell me about the Internal Weak Pull-Up of cyclone10LP.
For before and during configuration, is weak pull-up enabled regardless of the weak pull-up resistor setting?
best regard
Goto
Ash_R_Intel
https://www.intel.com/content/www/us/en/programmable/documentation/sxm1481253171919.html#btb1489040997115
"The user I/O pins and dual-purpose I/O pins have weak pull-up resistors, which are always enabled (after POR) before and during configuration."
Pull-up resistor is disabled by default in user mode.
https://www.intel.com/content/www/us/en/programmable/documentation/sxm1481253171919.html#vop1488428759003, Table 31
Value of pull-up resistor depends upon VCCIO voltage.
https://www.intel.com/content/www/us/en/programmable/documentation/egg1487191218630.html#bcq1487191162213.
See R_PU  value in Table 11.
Ash_R_Intel
Ash_R_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
