Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
altremote_update problem
hi all! i have a problem with altremote_update on Cyclone IV[/B][/B]
i'm testing program on de2-115 development board (altera cyclone iv 4ce115 fpga device).
my aim looks like that: after downloading factory configuration image (on device [/B][/B]startup[/B][/B]) i want to reconfig fpga into application configuration image [/B][/B]from pc[/B][/B].
i can change input parameters [/B][/B](param, read_source, data_in, write_param, read_param, reconf[/B][/B]) of altremote_update core from pc using uart and analyze data looking at data_out output port.
what i'm doing (algorythm):
[list=1]
[*]device and pin options -> configuration -> configuration mode - remote
[*]create 2 images (sof file). uart and altremote_update exist in both parts, but different leds blinking.
[*]create pof file with 2 images(page_0 and page_1). specify start adress(0x00000000) for page_0.
[*]download image into device. factory configuration starts as i expect.
[*]disable watchdog timer (watchdog enable = 0) [param=011, data_in=00000000, write_param=1]. remote_update core returns data_out= 00800000.
[*]set boot address for application configuration image. i experiment with 2 variants:
[list=1]
[*][param=100, data_in=00367f06(taken from map-файла), write_param=1]
[*][param=100, data_in=00000001 write_param=1]
[/list]
in both variants returns data_out= 00000000.
[*]set reconfig=1
[*]reconfiguration passes, but still factory configuration exists.
[*]here are reconfiguration trigger conditions (same for 6.1 and 6.2):
[list]
[*][read_source=00, param=111, read_param=1] = [data_out=00000000]
[*][read_source=01, param=111, read_param=1] = [data_out=00000004]
[/list]
[/list]
all operations taken from manuals(signaltap, modelsim):
- http://www.altera.com/literature/ug/ug_altremote.pdf (http://electronix.ru/redirect.php?http://www.altera.com/literature/ug/ug_altremote.pdf
- http://www.altera.com/literature/an/an603.pdf (http://electronix.ru/redirect.php?http://www.altera.com/literature/an/an603.pdf
i read both manuals multiple times, try different variants. please help.[/B][/B]
