Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
aoc compiler Error: Peak virtual memory: 496 megabytes
I try to compile my design. I issue the compile command as below
aoc device\opencl_cnn.cl -o bin\opencl_cnn.aocx --board a10gx -v
But, there is an error message, what is the meaning? I need to change my pc settting(virtual memory)?
aoc: First stage compilation completed successfully.
Error: Processing ended: Mon Oct 30 09:21:26 2017
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:00
Error: ip-generate FAILED.
Refer to opencl_cnn/opencl_cnn.log for details.
After enlarging the virtual memory, no Error: Peak virtual memory: 496 megabytes error message.
But, there is another error message as below:
The problem is about my pc hardware requirement not enough?
Error: Compiler Error, not able to generate hardware
Matt
