Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
arria V FPP programing doesn't work
hi,
I have a problem trying to program my arria V using a CPLD.
I am using a compressed rbf file and the MSEL pins are set as needed "10110" for compressed file with FPP x8 bit programming scheme.
the Dclk to Data Ratio is 2 and the Dclk freq is 25MHz.
I toggle the nConfig and receive an Ack from the nStatus however the conf_done never rises and no error is reported on the nStatus (remains high).
Is there a known issue with using this configuration scheme in arria V device ?
Can someone suggests me with a debugging possibility?
thanks
It drives me crazy !!!!:cry:
Tags (1)
Without going into the hardware, did you set the type of programming you were going to use in the Device & Pin Options settings in Quartus before generating the programming files?
thank you for the comment
yes the programming file is generated according to the scheme. (compressed, fppx8)
hi,
an update the programming is working now.
there was a mismatch in the qsf pins.
the data bus pins weren't in the correct order
