currently i am using Cyclone II family libraries to implement a bbs prng
i have insert a coding that i copy from internet, but i quite confuse on understanding the coding the coding i'm using to make modification: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity bbs is Port ( p : in integer; q : in integer; s : in integer; b : out STD_LOGIC_VECTOR(7 downto 0) ); end bbs; architecture Behavioral of bbs is begin process(p,q,s) variable x0,x1,s1,x_0:integer; constant p:integer:=11; constant q:integer:=19; constant n:integer:=551; variable b1:integer ; variable b2:std_logic; variable r:std_logic_vector(7 downto 0); begin s1:=s*s; x0:=s1 mod 1024; for i in 0 to 7 loop x_0:=x0*x0; x1:=x_0 mod 1024; b1:=x1 mod 2; if b1=1 then b2:='1'; else b2:='0'; end if; r(6):=r(7); r(5):=r(6); r(4):=r(5); r(3):=r(4); r(2):=r(3); r(1):=r(2); r(0):=r(1); r(7):=b2;--so it will be serially transmitted but parallelly observed x0:=x1; b<=r; end loop; end process; end Behavioral; please if there is someone can help me on explaining the coding?Link Copied
Try to simulate and understand the operation, Also refer the following points, In given code input ‘s’ has significance. Check operation of Mod operator. When s=0 leads to b1=0 so b2 =0 hence r<=b<=00000000, When s=1 leads to b1=1 so b2 =1 hence r<=b<=11111111. --- Quote Start --- r(7):=b2;--so it will be serially transmitted but parallelly observed --- Quote End --- In for loop, eventually output vector b (b<=r) is updated, Check screen shot. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel)- Mark as New
hi jatharvk, thanks for your information
i refer to your sreenshot, how you assign the input p, q, and s as 1 bit? because when i assign p, q and s node into the quartus II waveform window, it show 3 of these nodes are in 32 bits and since i need my output should be in random value, the output result is only showed as "00000000" and "11111111" how can i modify it to show the output in random value form?- Mark as New
--- Quote Start --- how you assign the input p, q, and s as 1 bit? --- Quote End --- No, in the code p, q, s are declared as integer, check screen shot. Output of the given code either 00000000 or 11111111. It depends on the value of b1. --- Quote Start --- how can i modify it to show the output in random value form? --- Quote End --- Refer attached IEEE paper & modify your code. Let me know if this has helped resolve the issue you are facing. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel)- Mark as New
--- Quote Start --- Hi, No, in the code p, q, s are declared as integer, check screen shot. Output of the given code either 00000000 or 11111111. It depends on the value of b1. Refer attached IEEE paper & modify your code. Let me know if this has helped resolve the issue you are facing. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel) --- Quote End --- hi jatharvk, thanks for your helping, seen i just try to design the bbs algorithm, now i will use back my lfsr prng design to continue my FYP project appreciate for your helping Your sincerely Vahn Heng
