Hello
my goal is to be able to test via Boundary Scan approach the following component
FPGA Altera Stratix V (5SGXMA3E2H29I2L)
I'm not able to found the bsdl file for this component .
Somebody can help ?
tks in advance , best regards .
FV
Hi, you may find the bsdl file at link below:
Thanks YuanLi
looking at this web site
You find the bsdl for the component 5SGXA3 but not for 5SGXMA3 typ .
I proved that the bsdl works for both pn but I think it should be fine to mention the compatibility with this pn too . Initially I had an hardware problem with my test environment , so it was really critical to understand if the problem was wrong bsdl or if there was a different reason .
Hope everything is clear , I suggest to put inside the bsdl the info about for which pn they are developed .
tks , best regards.
FV
Thanks for pointing out. I think the 5SGXB5 is meant for both 5SGXMB5 and 5SGXEB5.
Dear YuanLi
I confirm that bsdl for the component 5SGXA3 works for component 5SGXMA3 too .
tks .
Yes, it is. Thanks again for pointing out, i will feedback this to internal team and see how to improve the readability. Cheers
