i am doing a project at the university and the card that my fpga would be on is already printed (The FPGA is EP2S130). I need to get data from SERDES on another card (in LVDS), and because I cant use DPA (the ONLY pins that i can use are from BANK 6 which doesn't have DPA capability), I need to get the tx_outclock of the other SERDES along with the data. Now, the problem is that there arent any clock dedicated pins among the pins that i can use. Therefore I need to know if i can get the rx_clock (the othersides tx_clock) in normal LVDS pins and tell Quartus to ignore it. When i just connect the incoming clock to normal LVDS pins it generates error that the pll that gets the clock is driving the RX_SERDES and therefore it must get the clock from COMPENSATED pins. Please help me, My grade really depends on it :-). Thanks ahead, Itayyeka.Link Copied
For low and medium speed, deserialization can work in LEs. Hardware SERDES won't be usually without an input clock supplied through dedicated clock inputs and fast PLLs.
first of all, thank you for answering.
I didnt quite understand, is there a way to tell QUARTUS to ignore this problem if i can assure that the data rate would be slow or medium speed? And I am not really familiar with the term "LEs", what does it mean? again, thanks ahead.- Mark as New
Logic elements.
--- Quote Start --- I didnt quite understand, is there a way to tell QUARTUS to ignore this problem if i can assure that the data rate would be slow or medium speed? --- Quote End --- The problem is, that the Stratix II devices (as far as I'm aware of), don't have a clock path available to feed the clock input of a dedicated SERDES blocks from a regular IO pin. So you can't use the SERDES hardware.
thank you, those are bad news but thank you very much:-)
The other problem is, that PLL clock processing isn't available for clock from I/O pins. This means, that you need to supply the LVDS fast clock (1/2 data rate) from the transmitter side. Frame synchronization must use an additional signal or sync pattern embedded in the data stream.
