21615 Discussions
can UART be control using VHDL coding
can UART be assigned by using the VHDL coding. cause i am working on a stepper motor control n taught of using UART
You can define a module in VHDL language that handles communication between devices through the UART port, if that was the question...
my exact problem is i need to communicate between the normal vhdl code, which i use to generate pulse n transfer the pulse into the uart port to run my stepper motor.
With VHDL, you can write any control code you like.
A transmit UART is really just a parallel to serial converter that adds the proper start and stop bits to the signal. If you want to know if you can write behavioral VHDL (not soft processor based code) that communicates with a serial device, then the answer is yes.
Is your stepper motor something you command with serial commands? Can you control your stepper motor through hyperterminal or minicom? If so it is not very hard to transmit bytes using VHDL but you might have to convert between ASCII and binary.
Receiving bytes is a little bit harder, you have to oversample the incoming data stream to detect and frame the bits but not too hard.
dear davidsmoot,
the stepper motor driver that i use is the cytron SD20B. this stepper motor driver contains the UART input and output. But i am so blur cause i need to drive this motor but the problem with this project is i need to receive the angle as the feedback from the motor. And i am not sure how to do the ASCII and binary conversion also. Yet i am still trying to work on with it
entity uart is
port (
reset :in std_logic;
txclk :in std_logic;
ld_tx_data :in std_logic;
tx_data :in std_logic_vector (7 downto 0);
tx_enable :in std_logic;
tx_out :out std_logic;
tx_empty :out std_logic;
rxclk :in std_logic;
uld_rx_data :in std_logic;
rx_data :out std_logic_vector (7 downto 0);
rx_enable :in std_logic;
rx_in :in std_logic;
rx_empty :out std_logic
end entity;
architecture rtl of uart is
-- Internal Variables
signal tx_reg :std_logic_vector (7 downto 0);
signal tx_over_run :std_logic;
signal tx_cnt :std_logic_vector (3 downto 0);
signal rx_reg :std_logic_vector (7 downto 0);
signal rx_sample_cnt :std_logic_vector (3 downto 0);
signal rx_cnt :std_logic_vector (3 downto 0);
signal rx_frame_err :std_logic;
signal rx_over_run :std_logic;
signal rx_d1 :std_logic;
signal rx_d2 :std_logic;
signal rx_busy :std_logic;
signal rx_is_empty :std_logic;
signal tx_is_empty :std_logic;
begin
-- UART RX Logic
process (rxclk, reset) begin
if (reset = '1') then
rx_reg <= (others=>'0');
rx_data <= (others=>'0');
rx_sample_cnt <= (others=>'0');
rx_cnt <= (others=>'0');
rx_frame_err <= '0';
rx_over_run <= '0';
rx_is_empty <= '1';
rx_d1 <= '1';
rx_d2 <= '1';
rx_busy <= '0';
elsif (rising_edge(rxclk)) then
-- Synchronize the asynch signal
rx_d1 <= rx_in;
rx_d2 <= rx_d1;
-- Uload the rx data
if (uld_rx_data = '1') then
rx_data <= rx_reg;
rx_is_empty <= '1';
end if;
-- Receive data only when rx is enabled
if (rx_enable = '1') then
-- Check if just received start of frame
if (rx_busy = '0' and rx_d2 = '0') then
rx_busy <= '1';
rx_sample_cnt <= X"1";
rx_cnt <= X"0";
end if;
-- Start of frame detected, Proceed with rest of data
if (rx_busy = '1') then
rx_sample_cnt <= rx_sample_cnt + 1;
-- Logic to sample at middle of data
if (rx_sample_cnt = 7) then
if ((rx_d2 = '1') and (rx_cnt = 0)) then
rx_busy <= '0';
else
rx_cnt <= rx_cnt + 1;
-- Start storing the rx data
if (rx_cnt > 0 and rx_cnt < 9) then
rx_reg(conv_integer(rx_cnt) - 1) <= rx_d2;
end if;
if (rx_cnt = 9) then
rx_busy <= '0';
-- Check if End of frame received correctly
if (rx_d2 = '0') then
rx_frame_err <= '1';
else
rx_is_empty <= '0';
-- Check if last rx data was not unloaded,
if (rx_is_empty = '1') then
rx_over_run <= '0';
else
rx_over_run <= '1';
end if;
end if;
end if;
end if;
end if;
end if;
end if;
if (rx_enable = '0') then
rx_busy <= '0';
end if;
end if;
end process;
rx_empty <= rx_is_empty;
-- UART TX Logic
process (txclk, reset) begin
tx_reg <= (others=>'0');
tx_is_empty <= '1';
tx_over_run <= '0';
tx_out <= '1';
tx_cnt <= (others=>'0');
elsif (rising_edge(txclk)) then
if (ld_tx_data = '1') then
if (tx_is_empty = '0') then
tx_over_run <= '0';
else
tx_reg <= tx_data;
tx_is_empty <= '0';
end if;
end if;
if (tx_enable = '1' and tx_is_empty = '0') then
tx_cnt <= tx_cnt + 1;
if (tx_cnt = 0) then
tx_out <= '0';
end if;
if (tx_cnt > 0 and tx_cnt < 9) then
tx_out <= tx_reg(conv_integer(tx_cnt) -1);
end if;
if (tx_cnt = 9) then
tx_out <= '1';
tx_cnt <= X"0";
tx_is_empty <= '1';
end if;
end if;
if (tx_enable = '0') then
tx_cnt <= X"0";
end if;
end if;
end process;
tx_empty <= tx_is_empty;
end architecture;
i get this coding from internet... its states that it can be used to use for uart
