20704 Discussions
can't download program into EP2C5 via jtag
i can't download program into EP2C5 via jtag,so i test it use Quartus II tool named jtag chain debugger ,Quartus II know the device is EP2C5 TMS TCK TDO is ok ,but there is a Fork on TDI,then i use oscilloscope to test Circuit,
i found the wave of TMS TCK TDO is good ,but the TDI is not good ,
the wave of TDI is in the attachment
high level is 3.3V ,that right,but the low level is 1.68V (the half of 3.3),not 0V
,can anyone tell me why?
What kind of pull-up do you have on TDI? Isn't it too small?
the pull-up is 1k 0603 they are ame on TCK and other
okay... it could be the jtag cable that has a bad driver then... can you test it on another board?
