After compilation and generation of .pof file based on my flash (MT25QV256),
I'm trying to add it to the programmer and burn it through JTAG, but get the error:
"Cannot add target device MT25QL256 to device chain when in current programming mode.
the FPGA is cyclone V.
any suggetions?
Sasson
If it is in JTAG, can you change it to Active Serial Programming then try to insert the .pof file again?
Aiman
Hi Aiman,
Thanks for your reply.
When trying to do so, it's working.
But I need the JTAG mode.
thanks,
Sasson
You will need to generate .jic or .sof to used with JTAG.
Aiman
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
