21592 Discussions
change ticks to seconds
Hello, i wanna check the processing time of certain function by using alt_timestamp. When i get the freq using alt_timestamp_freq and divide it with number of ticks, the value is always 0. why?
Well, if I understand you correctly, are you dividing the frequency by the number of ticks? In that case after one second you will always get 0 as the number of ticks will be always higher than the frequency. You should do it the opposite way.
